Other Parts Discussed in Thread: TPS62913
Dear ,
my design is -15V output, the peak current is 2A around, continue current is 0.3A, can you provide the reference design about negative output for my refence, many thanks
Hi Cooper,
We don't have a reference design for that specific part or output, but I do have a good starter guide. Theoretically TPS54340B and most other devices can be used in an IBB configuration as long as the circuit is set up properly.
Here is an EVM where we configured the TPS62913. It shows a good example of how you can use MOSFETS as level shifters for auxiliary pins like EN or FB.
https://www.ti.com/tool/TPS62913-IBB-EVM
Andrew
Also, if you get stuck during the design process let me know. I'll help you out.
