Other Parts Discussed in Thread: PSPICE-FOR-TI
We are considering using the TPS7H4002 in a space grade design, and are currently evaluating it via Altium's PSPICE. However, there appears to be an issue with the supplied model (tps7h4002-sp_trans.lib).
I have assigned the model to an existing schematic symbol (as supplied by UltraLibrarian, via TI), and although simulation finished successfully, the output voltage is fixed at the input voltage, regardless of the values used for the VSENSE resistors. Altium also outputs an error message (along side "simulation stated" and "simulation succeeded" ) stating "unknown symbol "VSS"".
Can anyone shed some light on this?
Many Thanks
