Hi team,
do you recommend make an routing path between CSG pin and CSG and remove the vias on the CSG plane (bottom-right cornor) , instead of just connect to the multiple ground plane with vias?
that way we 'll have better PGND signal integrity, but I also worry if I remove the vias, the thermal will be worse since there's only one path back to PGND now.
may I know your suggestion?
