Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS54231: Tps54231
Part Number: TPS54231
I am Facing the problem to slowly open the duty cycle, when input voltage increase to set voltage duty cycle suddenly open to 100%. output voltage is vary before reaching the set output voltage.
  • Hi
    Ruby will reply you next Monday.
    Shuai
  • HI Adarsh
    Here I would like to confirm some details:
    1. What is the Vin, Vout, Iload? A schematic may help here.
    2. Would you please do me a favor to capture the waveform of the issue? I would like to check the Vin, PH voltage, Vout and inductor current.
    3. Regarding "when input voltage increase to set voltage duty cycle suddenly open to 100%", do you mean you want the device work under 100% duty cycle condition?  I am afraid that the device can not support 100% duty cycle
    BR
    Ruby
