Register settings
Is there anything required on the SW side when setting registers
in LP873347RHDT?
(Especially GuI.)
Register settings
in LP873347RHDT?
(Especially GuI.)
Hello Hiroyuki,
It really depends what you are trying to do? Could you elaborate a little bit?
LP8733 uses standard I2C communication and there is nothing special in that sense. You can use LP8733 EVM+GUI to try the configurations and test I2C sequences if you like.
Thanks.
Tomi Koskela
Hello Hiroyuki,
You can see the default settings for this device in the Technical Reference Manual. https://www.ti.com/lit/ug/snvu679/snvu679.pdf
If the default settings are ok, you don't need to change any registers. You just set the EN pin high and the converters will start with the pre- set voltages/sequencing.
If you need to change some settings, please refer to Configuration Guide: https://www.ti.com/lit/ug/snvu582a/snvu582a.pdf
Thanks.
Tomi Koskela
