Two TIDM-HV-1PH-DCAC purchased for an application, two engineer independently went through 3 build option, followed by the Demo Built using the Design Guide,
Both applied restive load of 100 ohms per the design guide, using the DEMO Build, the IGBT Bridge failed catastrophically.
After replacing all the components of the Bridge, this time as suggested as an option, only DEMO built applied (Out of the BOX), same outcome. Out of the IGBT!!!
An Out of BOX Demo with a linear load should not encounter this type of problems, the end application will be to power up a non-linear load (full wave bridge and caps).
You have my contact information, please review and advise.as soon as possible. Thanks in advance.
