TPS7A8300: Specification on the ENable Time
Part Number: TPS7A8300
Hello E2E Experts,
Good day.
Do you have specs for the Power-off time (when Ven is removed?)
Thank you in advance for your support.
CSC
  • Hi CSC,
    The turn-off time as you have described it is not specified for devices such as TPS7A8300 that do not have an active discharge circuit because the time it takes to discharge is dependent on the size of COUT and the load current since the load is the main discharge path.
    Nick
