Iam designing a USB-C battery pack charger for charging two lithium ion polymer batteries of 6000mah. The number of batteries may vary from 2 to 3 (hardware or software configuration may change accordingly).
The solution that i designed is as below
1) In the solution we are using balance charger.is it ideally required for a 2 cell fixed battery??
2) Do you have any alternate / simple solution for the same or do you recommend any alternate parts for the same function??
Sreekanth MK
