Other Parts Discussed in Thread: TPS62810M
I am designing a 3.3V regulator solution with the TPS54316MPWPREP. Our FPGA will control the enable signal on the regulator so that it becomes enabled only when the ambient temperature read is above -40C. Is this solution as simple as having a pull-down resistor on the Enable line and driving a logic high to it when the enable conditions are met? How does this scenario affect having an external cap for the soft start?
