Hi Team
There is a good new that we could DIN TI solution!
May you help check the difference of O917A14DTRGZRQ1 and O917A154TRGZRQ1?
Hi Team
Hi Kygo,
O917A14DTRGZRQ1 OTP information can be found in TPS65919-Q1 and TPS65917-Q1 User's Guide to Power DRA71x, DRA79x, and TDA2E-17 and O917A154TRGZRQ1 OTP information can be found in LP87565C-Q1 and TPS65917-Q1 User’s Guide to Power DRA7xxP and TDA2Pxx.
Layne J
Hi Layne
Thank you for your feedback,
1.Are they P2P compatible?
2.Can O917A154TRGZRQ1 directly drop in O917A14DTRGZRQ1 ? THX
3.If can not directly drop in , what should be paid attention to in the design ?THX
Hi Kygo,
These orderable part numbers are the same base part with different OTP programming. This OTP programming determines default power up/down sequencing and output voltage (among other things) that will change how the part is used. The default voltages and sequencing is covered in the documents I referenced above. The customer will need to determine which of the OTPs we offer meet their voltage and sequencing requirements to choose the proper OTP for their system.
Layne J
