Other Parts Discussed in Thread: AWR1843,
In the figure below, I2C connection is not made with AWR1843, but I2C connection is made with AWR1843 Boost.
Is it okay to assume that the I2C connection is omitted in the figure below?
Hi Hiroyaki,
Yes, you are correct. The I2C connection is omitted from the figure but real application usually has I2C connectivity between the PMIC and AWR.
BR,
Samuli Piispanen
thank you for your reply.
What is this I2C actually connecting for?
please tell me in detail.
If I don't use this PMIC, is it okay if the AWR1843 doesn't use I2C communication?
Hi Hiroyuki,
I don't really understand the question. The bus could be used to, for example, read the status registers of LP87702-Q1 and configure the watchdog during long window.
BR,
Samuli Piispanen
