1) What is the PSRR value(Frequency 10Hz to 10Mhz) for the Boost converter?.
2) We are trying to measure the PSRR value. Note : The input voltage is 3.3V & Output voltage is 6V
Our test set up is injecting noise (Modulating 1Vpp AC+3.3V DC).
while we measuring, the higher frequency start from 100KHz start to attenuate to mV in input side of Boost converter. and also we removed the input capacitance but the still the issue is not resolved.
Could you please help on this?
