TPS62290-Q1: Under what conditions can output MOS lower tube be damaged easily?
Part Number: TPS62290-Q1
  • Hi Xiaofu,
    Thanks for your question.
    Are you saying that you have found the low side mosfet damaged (low resistance) on  TPS62290-Q1?
    Can you provide further info?
    If this is the case, one possible explanation for this damage is an overvoltage on the SW node exceeding the Absolute Maximum Ratings.
    Stefano
