Other Parts Discussed in Thread: BQ40Z50
Hi, TI Support Team
The following inquiries have been received from customers.
- Is it possible to make the time from PRES signal recognition to battery voltage output longer than the present?
If you check the BQ40Z50-R2 Technical Reference, you will find the following.
"Polling of the PRES pin continues at a rate of once every 1 s."
- Is it possible to change the polling cycle of PRES to about 2s by changing the BQ40Z50-R2 register setting value?
- Is there a way to change the timing by adding a CAPACITOR to the PRES circuit?
Thanks.
MJ
