I would like perform a current calibration with the BQ35100 on my application. To convert the calculated calibration data (ccGain, ccDelta) to the rawData, a floating point conversion is necessary.
In the Technical reference manual on page 18 (Figure 3-8), a flow chart shows the function. Two things I don´t understand here:
- "Byte 2 OR with 0x80": What do you mean with this expression? Can you please explain that a bit? What´s to do here?
- "rawData[byte3] = byte0": byte3 is not defined or missing in the flow chart. Can you check that please?
Best regards
L-Unit
