TPS7A88: Replacement Part
Part Number: TPS7A88
Other Parts Discussed in Thread: TPS7A91, TPS7A92, TPS7A83A, TPS7A89, TLV752
I am looking for a replacement chip to replace both the TPS7A88 and TPS7A91 since both are out of stock on TI.com. What is the recommendation for chips to replace them both? The x91 is outputting 5V and x88 is outputting 3.3V or 1.8V with a 5V input.
  • Hey Elizabeth,
    For TPS7A91 our best replacement would be TPS7A92, however if you need a device in stock I recommend TPS7A8300ARGWT.
      TPS7A91 TPS7A92 TPS7A83A
    AEC Q100 NO NO NO
    Output Options Adjustable Output Adjustable Output Adjustable Output, Programmable Output
    Iout (Max) (A) 1 2 2
    Vin (Max) (V) 6.5 6.5 6.5
    Vin (Min) (V) 1.4 1.4 1.1
    Vout (Max) (V) 5.2 5.2 5.2
    Vout (Min) (V) 0.8 0.8 0.8
    Fixed Output Options (V) - - -
    Enable YES YES YES
    Power Good NO NO NO
    Output Capacitor Type Ceramic Ceramic Ceramic
    PSRR @ 100KHz (dB) 48 48 40
    Noise (uVrms) 4.7 4.7 4.4
    Accuracy (%) 1 1 0.75
    Vdo (Typ) (mV) 130 260 75
    Iq (Typ) (mA) 2.1 2.1 2.8
    Thermal Resistance θJA (°C/W) 57 57 43
    Min Package Area (mm2) 6.25 6.25 12.25
    Package Type SON SON VQFN, VQFN
    For TPS7A88, I would normally recommend TPS7A89 due to it being pin to pin with higher maximum current. So in this case I recommend TLV75201PDSQT which is also a dual LDO which can have the same outputs you need.
      TPS7A88 TPS7A89 TLV752
    AEC Q100 NO NO NO
    Output Options Adjustable Output, Dual Output Adjustable Output, Dual Output Adjustable Output, Dual Output
    Iout (Max) (A) 1 2 1
    Vin (Min) (V) 1.4 1.4 1.5
    Vout (Max) (V) 5.2 5.2 5.5
    Vout (Min) (V) 0.8 0.8 0.55
    Enable YES YES YES
    Power Good NO NO NO
    PSRR @ 100KHz (dB) 48 35 45
    Noise (uVrms) 3.8 3.8 53
    Accuracy (%) 1 1 1.5
    Vdo (Typ) (mV) 130 260 225
    Iq (Typ) (mA) 2 2.1 0.025
    Thermal Resistance θJA (°C/W) 33 33 74.6
    Min Package Area (mm2) 16 16 4
    Package Type QFN QFN WSON
