The TI E2E™ design support forums will undergo maintenance from Sept. 28 to Oct. 2. If you need design support during this time, contact your TI representative or open a new support request with our customer support center.
TPS51123: VREG5 cap value
Part Number: TPS51123
Hi Team,
A Japanese customer can not post issue in E2E, so I help him to post this technical query.
The 33uF (P1) connection to VREG5 of TPS51123 is described in the data sheet.
I understand. Also, VREG5 is involved in the Switcher controller block on P9.
I also understand that you are doing it.
There is always data with variable capacity when deciding 33uF.
If there is a history of changing the capacity to 33uF like 22uF, 33uF, 44uF
think. Is it possible to see the data when the capacity is changed?
Thanks.
Frank
