Other Parts Discussed in Thread: BQ79616
I am trying to implement the sleep to active ping. but it doesn't seem to work, it shows some weird behavior. I use a ring architecture with heardbeat and fault tone. I already checked and this works perfectly in sleep (no fault tone in sleep only when fault happens). Now I masked the FAULT_COMM1 to avoid that the fault pin would get low when sleep to active tone is detected. But still with 275us Tx pin low and the dummy read writes the OTP_ECC_DATAIN1 register. The fault pin gets low and i am not able to do any reads, so i can't read the fault registers (looks like it still is in sleep but puts the fault pin low). Is this a know issue is there a solution?
