what is the current value that the voltage will draw at the input.?
ınput voltage 12v in my desıgn. how much current will it draw at 12v input. where does it say on the datasheet
Hi Gizem,
Usually there is no input current data in any Buck converter datasheet. It really depends on customer's application and not IC spec. Because input voltage, output voltage, output current, switching frequency and even feedback resistors affect the efficiency and power loss. If you have same setting with LMZ12001 EVM user's guide, you can derive the power loss based on efficiency curve and then divided by your input voltage to get input current.
Hope this helps,
Nancy
