Part Number: BQ24195L
Other Parts Discussed in Thread: BQ25895
Let's consider a system with the following supplies and loads
| Vadapter supply | 5V load | Sys load | Battery supply | |
| Voltage | 5V | 4.5V to 5.5V | 3.5V to 4.25V |
500mAh Li-Ion, 3.2V to 4.1V |
| Current | Max 2A continuous | 100 mA max, 50 mA typical |
300 mA typical, 2A peaks (GSM modem) |
CC: 200 mA, CV term: 25mA |
| Remarks |
Main supply, could turn off To Vbus pin |
From Vadapter or PMID boost |
From Vadapter buck (SYS) or battery supplement when Vadapter is off |
Backup battery when Vadapter is absent |
The questions would be
- Would BQ25195L work for the Sys load described (2A peaks) considering we configure input current limit as 1.5A, system voltage limit as 3.7V ?
- What is the transient response for sys voltage during the 2A peaks?
- Can we set input current limit as 1.5A and do fast charging current as 200mA since the battery capacity itself is 500 mAh?
- The 5V load needs to be powered from Vadapter when available and then from PMID when not available.
- We can keep monitoring Vadapter and enable boost operation when Vadapter voltage falls to 0V?
- When boost operation is on-going and Vadapter power comes back on, how would BQ25195L handle this and what should host do?
- Any other aspect we are not aware of or not considering?
Thanks, Prithvi
