PTH05050W: PO# 11AJ49651 -- AGIH-0950-5085 -- HS Code issue
Part Number: PTH05050W
Hello TI Team,
we have one urgent shipment for MPN PTH05050WAZ with PO# 11AJ49651 for which our broker confirmed that shipment will be cancelled due to inconsistent HS Code from Flex and TI so we need your help to provide correct HS Code and provide answers of below questions. so please help to advise on this ASAP.
Flex HS code: 8504401400, it means a voltage-stabilized supplier. so please check and confirm if it can stabilize the voltage?
TI HS code: 8504409110, it means a semiconductor module with a converting function. Please provide the structure and components of this item, if contains any semiconductor devices, what are they?
Thanks & Best Regards,
Shubham Govekar
Senior Analyst - Global Procurement & Supply Chain
  • Hi Shubham,
    This is not the right place to ask about shipping codes, but I can address what the PTH050505W does technically.
    This is a buck converter power module, which integrates the controller plus MOSFETs (these are silicon devices) as well as numerous passive components.  These components provide a converting function.
    The device also provides a regulated, stabilized output voltage.
    Chris
