Other Parts Discussed in Thread: TPS25750EVM, TPS25750, , TPS65988EVM
I am following TPS25750EVM design and I will connect a 4S 4.5A lipo battery. I have some questions regarding output power of this EVM.
- What will be the system voltage and current when input source is present and not present. The 100W PD adapter is connected as a input source (see attached).
I am curious about the output power of this EVM. I will use it as a sink to charge the battery and get the output voltage at SYS pin. Correct me if I am wrong about the term source/sink.
Let's say Tps25750 negotiate a power with adapter at 20V 5A.
- What will be the input to BQ25792 in that case? I believe the input power can be only 20V 3.3A to BQ.
- If that is true then what will be the SYS pin voltages and current considering 4S lipo battery connected with BQ.
