The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS82084: Stability Analysis
Guru 10450 points
Part Number: TPS82084
My customer has a question about the stability analysis of TI power module.
Are there any parts that may cause stability issues among the TI power module products below? What part is it?
  - TPS82084SILT, TPS82085SILT
Thank you.
JH
  • Hi JH,
    There should be no stability issues with these parts if the output capacitor is below 150uF. For higher values of output capacitors, it is recommended to check startup behavior and Bode plots to estimate stability.
    Varun
