Hi Guru,
Please see my comments/questions below regarding your questions.
Khalid
Hi Khalid,
1) What I tried differently before with LDO off helped me measure current at about 0.32 A that I verified using a multimeter. But multimeter reading was different and corresponded to value of ICHG that I had set. But after your suggestions I did set Reg31[7] = 0; got it working
The sequence that actually worked was disabling Ext_Ilim and Manually setting MinSysVoltage. The MinSysVoltage should automatically detect type of cell but in our case it indicates 4s i.e 12.8 V instead of 1s 3.584 V which I manually set. This got the pmic working properly. Any reason why this could be the case?
2) and 3) Noted
4) VBUS = 9.6V
VBAT = 3.6V
ChargeCurrent = 128mA and read back value was not changed to 4A (Note: En_EXTLim was high and LDO was disabled)
Hi Guru,
Khalid
1) Noted Khalid.
2) I've actually set Reg12 to 0x020e completely disabling WDT. The current charge resistor is not reset in it's value.
Guru
