hi,
here are some CMTI questions want to confirm:
1 is CMTI only for isolated driver?
I supposed it's also important for half bridge driver since the upper mos's ground is floating with common voltage changing. but I don't found "CMTI" in their datasheet.
2 how to estimate the CMTI?
I know the CMTI should be common voltage/transition time. common voltage usually is bus voltage but what's the estimated as transition time? can we calculated as the rising time of IGBT/MOS?
thanks,
B&R
Yuan
