Other Parts Discussed in Thread: LM74800EVM-CD
Does it have negative voltage at OV pin(or BATT_MON) when Reverse Battery ? I did the test and found there will be a negative voltage at OV pin(or BATT_MON). Can you explain it? We would like to use the pin to MCU ADC for the battery monitor, but the negative voltage is not acceptable. Do you have any idea?
Hsing
