Hi support team,
I don't think the TPSM8282x has a SW pin.
SLVSEP0F has a description of VSW in TEST CONDITIONS of Electrical Characteristics and SW waveforms.
Is there a way to observe the SW voltage?
Dice-K
Hi support team,
Dice-K
Hi Dice,
The inductor on top of the package has one terminal connected to SW and one to VOUT. You can probe the SW node by contacting the corresponding terminal of the inductor.
Varun
Hi Varun,
Thank you for your reply.
Is the SW side of the inductor the 1-pin side of the TPSM8282x?
Dice-K
Hi Dice,
Sorry for the inconvenience. The reason for not describing this is because, usually there is no need for customers to check this. And there is a risk of damaging the device trying to probe the SW node.
Varun
Hi Dice,
It's just a precaution against damaging the inductor or the substrate of the module by applying too much pressure with the needle tip of the probe.
Varun
