Can you please verify if the following circuit would be work reliably.
Hi Akash,
Ensure that you are using enhancement type MOSFETs for M1 and M2, as the OUT pin is active high. Additionally, I recommend using 1Mohm pulldown resistors from gate to source for your n-channel MOSFETs.
Andria
Thank you.
Can you pls tell which configuration is better: Common drain or Common source
Hey Akash,
TI's references for FET designs in BMS are common drain.
Caleb
