Other Parts Discussed in Thread: LM5122
Dear Sirs,
I am currently designing a boost circuitry by using LM5122QMH/NOPB. Firstly, I use Web bench to look at the result. The Web bench result shows that M1 pd is 2.908W(at Vin=8V;Iout=7A) and Rthia of M1 mosfet is 57degC/W per its datasheet, the ambient temperature is 30 degC. The junction temperature calculated is 2.908*57+30=195.756 degC. However, the M1 Tj curve in the web bench report shows 110 degC.
Can you help to explain how this 110 degC come from? Is this 110degC measured on a real PCBA board?lm5122-q1.pdfWBDesign63.pdf
John
