Hi Team,
The RM value changed when the battery was inserted and removed while the battery was being discharged using the application.
Before the battery was inserted and removed, the RM value was updated by the Coulomb count, but when the battery is inserted and removed, the RM value is predicted by OCV measurement, so it is estimated that the RM value has changed.
Does the accuracy of the RM value measured by OCV when inserting and removing the battery deteriorate as the discharge rate of the battery increases?
Would you please let me know if there is a possible cause?
