Hi TI,
As per the datasheets the Max charge voltage for 1S configuration is 4.192 mV .
But the Battery I'm using is LiFePO4 1s 3.2V 2200mAh, The Max charge voltage for this Battery is 3.6V .
so my Question is
1) can BQ25700A Automatically changes the Maxcharge voltage to 3.6V for LiFePO4 battery ? or it will charge the Battery to 4.192mV which is Default for 1S configuration
2) After Every POR the default value for Maxcharge voltage register is 4.192mV so if it cannot detect LiFePO4 battery 3.2V then every time i need to Program the registers manually ?
