Hi team,
Here's an issue from the customer may need your help:
When using the gauge to detect battery charge, the customer has the following 2 questions:
1) When the voltage current has been calibrated, the load is connected and the current sample will output normally, but negative numbers are shown. After power down, then powering up, current no longer shows properly when load is connected, always 0, and must be calibrated again. Why?
2) Is there a way to quickly write the configuration file to other new chips instead of using bqStudio to burn the configuration file one by one?
Could you help check this case? Thanks.
Cherry
