I am looking for the best way to add a delay of about 10 seconds between when power is applied and when the LMR16010 is enabled. Adding a simple RC to the EN pin seems like an easy way to do it. However I think it may be even easier - because of the internal 1uA current source in the EN pin, can I simply add a capacitor from EN to GND, with no resistor, and let the current source handle charging the capacitor? This would be even better than the RC, which would have been dependent on Vin (my applied voltage can be variable).
So, first, any concerns about this? 10uF gives me about 12 seconds. Would you want to add a series resistor between the the capacitor and EN, to potentially limit current into the pin? Or is that unnecessary for this pin?
Second, I would want the capacitor to quickly discharge when power is removed, so I'll add a diode from EN to Vin, so when Vin is pulled down the capacitor will discharge through the diode, and re-arm the delay for the next time power is applied.
Does this all sound reasonable? Any concerns about potential harm to the EN pin?
