CSD18540Q5B: Thermal Characteristic of MOS
Part Number: CSD18540Q5B
hi TI  member
From  the datasheet of MOS , we can find the thermal information :
About RθJC --Junction-to-case thermal resistance  ,  how to define the case thermal  ,  top case or the bottom case of the MOS ???
when check some MOS from Infineon, you  can find two RθJC , one is bottom case , one is top case
'cause  I don't know the internal structure of TI MOS, when adding heatsink , which side should  install , from the Top side of the MOS ,or  the Bottom side  ?
thanks
