Hello team,
For my application, I need an high side switch to switch 5V supply to single load consuming less than 500mA of current.
Can you please confirm if TPS2H160 IC can be effectively used for a 5V switching?
Thanks in advance!
Hello team,
Thanks in advance!
Hello Srilakshmi,
The TPS2H160 has a recommended operating condition for supply voltage ranging from 4V to 40V so in your case, 5V would work well.
It may also be beneficial to take a look at our load switches portfolio to see if one of the switches there better suits your application.
I have included the link here: https://www.ti.com/power-management/power-switches/load-switches/products.html
I hope this helps, Let me know if you have more questions.
Quentin
Hello Srilankshmi,
The TPS1H160-Q1 has the same recommended operating condition for supply voltage ranging from 4V to 40V. So in your case, 5V would work here as well.
Quentin
