Other Parts Discussed in Thread: UCC28740, UCC28720
- I generated a Mathcad sheet for datasheet example. Then updated it with my design. I am noticing that my High line (275vac and 400vdc) Frequency at current limit , I am above 130khz or close to it, However in datasheet example high line frequency is only 62khz. Is there any general guidelines need to be followed here?. Since max frequency is 130khz I assume for higher frequency requirements, after turn off, the delay extends until 130khz is met and next cycle start. The losses associated with ringing is the only drawback here waiting for 130khz?
Please review attachments
- In Lm5023 datasheet Eq 33 introduces the term Freq_comp
- In layman's terms , Can anyone explain the purpose of calculating Freq-comp
- In my design the comp value iam getting is >130khz. Can I proceed with R external and Rff calculations with the value (196khz) I am getting ?
/cfs-file/__key/communityserver-discussions-components-files/196/Datasheet-Example-mathcad.pdf
/cfs-file/__key/communityserver-discussions-components-files/196/My-Design-Mathcad-Rev-1.0.pdf
/cfs-file/__key/communityserver-discussions-components-files/196/ac-voltage-details.pdf
