Hi Team,
Could you possible help to check if customer could remove the output clamp diode which we recommend in datasheet? Since currently, customer with 100nF output capacitor and with 7m cable from LED+ and then short the cable to ground, it shows now minus voltage in VLED+ side without the clamp diode, so, customer is considering remove the output clamp diode, but not sure if there still has some risk here.
Could you possible help to share some comments under what kind of test condition or design condition would there see a minus voltage in output side? Thank you very much for your help to confirm.
Best regards
Jie
