Hello:
What's the difference betwwen TPS7B8225QDGNRQ1 and TPS7B8250QDGNRQ1, I see no difference in Datasheet.
Is TPS7B8225QDGNRQ1 for output voltage 2.5V and TPS7B8250QDGNRQ1 for voltage 5.0V? Thanks!!!
Hello:
Hi Jimmy,
That's correct, the only difference is the internally-programmed output voltage.
Nick
Hi Nick:
I see the lowest output voltage is 3.3V, I see no 2.5V in datasheet. Can you help explain it? Thanks!!!
Hi Jimmy,
The 2.5V version was added in datasheet revision G. I'm not sure why the most recent revision (revision I) does not have the full revision history, but here's the notes for revision G.
Nick
