In the datasheet I found:
"The LM5106 is a single PWM input gate driver with Enable that offers a programmable dead-time. The dead-time is set with a resistor at the RDT pin and can be adjusted from 100 ns to 600 ns. The wide dead-time
programming range provides the flexibility to optimize drive signal timing for a wide range of MOSFETs and applications."
But when I look at Figure 19 it seems that the maximum RDT is 110k.
So my question is, can we go with the RDT above 100k? Can I get a dead time of 800ns using a 150k resistor?
I know that the temperature will change the resistance, but at normal temperatures can we use Figure 19 to extract the correct RDT value? Because that sentence at the beginning says otherwise...
Pedro S.
