LP55231SQEVM: LP55231SQEVM can't compile
Part Number: LP55231SQEVM
Windows 10.  I installed the Eval kit software and the PSPad editor and set it up as described in the User's Guide.  I got the eval board up and running and am trying to compile a program.  At first the OS wouldn't let the lasm.exe compiler to run so I changed it's attributes to run in Vista compatibility mode as Administrator so it will run.  In the PSPad editor the "Compile" function is grayed out (there are no spaces in the path to lasm).
I cannot find any documentation on lasm to know how to run it manually.
Also, the Eval User's Guide says that the file "usblptio.dll" should be in the eval software folder but it was not supplied with the kit.
Doug
