Hi team,
Is it possible to create a negative power supply for the TLVM136x0?
If so, I would like to know how to connect it.
Or, if you have an application note, I would like to have it.
Sincerely.
Ryu
Hi team,
Sincerely.
Ryu
Hello Ryu,
Yes, it should be possible. Here is an example app note on how to configure the Buck as an inverting buck-boost:
https://www.ti.com/lit/an/snva856a/snva856a.pdf
Please look at figure 2.
Also, please note the voltage range and output current range limitations when going to inverting buck-boost. Those are described in section 4 of the app note.
Denislav
Also, please refer to the device datasheet (page 27) where the inverting configuration is already discussed.
https://www.ti.com/lit/ds/symlink/tlvm13620.pdf#page=27
Denislav
