I have been using an LM 334Z in its standard (single resistor) configuration to produce a 10 micro-amp current source for some 1 Kelvin temperature diodes I am using. In order to make a more robust system, I tried modifying the LM 334 circuit to the zero temperature coefficient configuration seen in Fig.15 of the data sheet. However, the math to sort out the exact R1 and R2 values has confused me. By time i fully worked it out and tested it for what I though would produce a 10 micro-amp source, I was producing mili-amps. If anyone has set up this configuration successfully, please let me know how you calculated your R1 and R2 values, or if you feel charitable, please let me know what R1 and R2 values I should use for Iset = .00001A.
Thanks in advance,
Sean
