TPS23750: TPS23750 replacement
Part Number: TPS23750
Other Parts Discussed in Thread: TPS23758, TPS23753A, LM5070, LM5071
I've been designing a product using the TPS23750 for a 5V supply but have realised that supply problems and the possibility of EOL make this an unwise choice. Can someone suggest a suitable replacement, preferably one that uses similar topology and is more readily available? This is a low power application, so the 13W rating will suffice.
Thank you.
