TPS65132: Help check the timing of MIPI Power on
Part Number: TPS65132
Hi team,
Help check if the default voltage of the TPS65132A0YFFR bias IC can be changed to 6V?
If can't change, pls help confirm in the power-up process, the timing of AVEE—MIPI Power on refers to whether the bias voltage can start operating at the default voltage or is after normal stabilization to the 6V output.
Please help confirm the following wave.
Thanks!
Best regards.
Lillian Liu
