Other Parts Discussed in Thread: TPSM8D6C24
If the current capacity is neglected, is it possible to replace only the TPSM8D6B24 in the design circuit of the TPSM8D6C24?
Thank you.
JH
Thank you.
JH
JH Shin,
Due to the difference of inductance, it is generally recommended that the TPSM8D6B24 use an ILOOP value 1 higher than that of the TPSM8D6C24 to avoid loss of phase margin in the voltage loop. The Compensation value is programmed with the MSEL1 resistors.
