The only difference is I added a 0.22uf between the NR to GND but even I remove it, the issue is still there...
Hi Li
Can you please share your circuit schematic?
Trailokya
Hi Li
Couple of question/suggestions -
Trailokya
Hi Trailokya, Yes, I have 0.47uf at input , 0.47uf at NR pin and about 1.5uf at output
The output is very stable and on my 7.5 digit DMM it is only moving the last digit. the output noise is very low, I only have passive probe so it is berried in the noise since the entire thing is powered by a 9V battery. I used TI MSOP to DIP conversion board and all components are directly soldered on the pin. Also entire device is start grounded in a 3D printed plastic housing.
Hi Li
I want to see your overall schematic (interfacing blocks with the REF). Can we discuss it offline?
I will send you private message.
Trailokya
