Part Number: TPS564247
We are using TPS564247 in our design for generation of 2.5V,1.2V and1.8 V from 5V.
Kindly review the schematic(PFA) and provide feedbacks (if any).
Ashish Kumar Pandey
Research Engineer
TWDM-PON H/W
CDoT-Delhi
Ashish Kumar Pandey
Research Engineer
TWDM-PON H/W
CDoT-Delhi
Hi Ashish,
Based on current EN divider resister, when Vin is 5V, all sample are enabled on. it's no problem. but it's marginal. could we set when 4.5V input voltage could enable all sample which means IC begin to work at 4.5V input voltage?
please provide inductance value.
BRs,
Edwin.
Hi Edwin,
Thanks for the review.
We have provided the I/P range from 4.5 V to 5.5 V in our calculations. Attached are the WebBench designs for your reference.
We have used same inductor(PFA datasheet) for L9,L12,L13
Ashish
/cfs-file/__key/communityserver-discussions-components-files/196/SRU1028_2D00_1R0Y.pdf
/cfs-file/__key/communityserver-discussions-components-files/196/3000.WBDesign8.pdf
/cfs-file/__key/communityserver-discussions-components-files/196/4331.WBDesign7.pdf
/cfs-file/__key/communityserver-discussions-components-files/196/0842.WBDesign6.pdf
Hi Ashish,
Got it. Inductance is no problem. It's suggested to change EN down divider resister to 86k ohm. so all parts can be enabled on at 4.5V input voltage.
BRs,
Edwin.
