Because of the Thanksgiving holiday in the U.S., TI E2E™ design support forum responses may be delayed from November 25 through December 2. Thank you for your patience.
TPS562207: Simulations using Pspice
Part Number: TPS562207
Dear Power management team
I’m trying to perform the following simulation:
Im having 2 main problems with it,
  1. When you look at the voltage divider at the right you will see that the division is very odd, the voltage across each resistor should be the same.
  2. If im looking at just a single device (tps562207) and trying to get 1.8V output, no matter what im putting in the voltage divider for the feedback loop im getting the same 1.035V result.
