Hi Team,
Good day. I am posting this inquiry on behalf of the customer.
"I plan to use LM2678S-12 as 26-27V regulator driving feedback (FB pin) through resistor instead of direct voltage output, see below.
Used formula from datasheet: Vout=Vfb*(1+R1/R2)=1.21V*(1+(22k3+30k)/2k5)=26.5V, where 22k3 is value of internal resistor for 12V.
Please advise whether this approach is ok if all other recommendations for inductor, capacitors, and diode are met as if the regulator was LM2678S-ADJ type.
If it's ok, can the fixed LM267x family regulators be used as a replacement for ADJ type using the external resistor generally?"
Thank you.
Thank you for extending your help.
Kind regards,
Marvin
