Hello.
I have a couple questions about a datasheet for a load switch. The part number is tps7h2201-sp
In figures 4 and 5, max pull down spec is at 138 ohms and graph doesn't go anywhere near that for load switch Rpd. How was this value determined?
If we consider BOL, EOL, Bond, TMP, SOLD tolerances, is it better to use max or typical value of the pull-down resistance? We are operating in a region of about 0 to 30 deg C, which correspond to about 18 to 23 ohms respectively.
